Seite 1 von 2
Clippercreek-Ladegerät 16 A
Verfasst: 20. Aug 2012 20:41
von fleischwurcht
Ich bin Franzose aus dem Elsass. Ich spreche Elsässisch aber habe Schwierigkeiten mit denn technischen Deutsch Wörter, deshalb werde ich auf Englisch weiter machen: Entschuldigung !
I have my Ampera Cosmo Pack since April and I'm registered on this forum since a few months. I registered here because I had a lot of charging problems with my Voltec charger and I know that some of you have the same problems. I looked for a solution everywhere and I think I finally found one which I would like to share with you.
I bought the portable ClipperCreek ECS-20 charger (
http://www.clippercreek.com/products.html) which charges my Ampera at 15A without any problems.
While the Voltec charger is at default, the ECS-20 charges smoothly and continuously at any time of the day or night. The plug is meant to work in Europe up to 20A, so no heating problems even during a complete charge.
I found this solution, so I hope it will help some of you to circumvent the troubles with the Voltec charger, until Opel proposes a real solution.
Re: Fleischwurcht aus dem Elsass
Verfasst: 20. Aug 2012 21:26
von vaja
Hi. Many thanks for sharing that. I can not find the product ecs20 on the link you send..does it have another/aditional product description?
Does it fully charge you car in 3,5 hours and 80% in half of that time?
Thanks again.
Verfasst: 20. Aug 2012 22:24
von Hybrid_man
Hello Fleischwurcht,
welcome and good luck with your Cosmo pack!!!
Where did you buy the Clippercreek charger, how much does it cost ?
ECS-20 is the 15A/16A version of the International 3.7kW - 230VAC Charger (see on the mentioned site from clippercreek).
Unfortunately it is not switchable to 10A or less.
Regards
Verfasst: 21. Aug 2012 00:16
von Jürgen
Hallo fleischwurcht,
-(bedeutet der Namen das -wonach er klingt ? :-) )
...jedenfalls ein Herzliches Willkommen!
Es würde mich freuen, wenn du -abgesehen von den Technischen Fragen und Begriffen,-
ab und zu deutsch schreiben würdest, ansonsten verstehe ich nur noch "Bahnhof"... :-)
Schönen Gruß,
Jürgen.
Verfasst: 21. Aug 2012 06:13
von Kratus
Bonjour Fleischwurcht, et bienvenue ici!
merci d'avoir posté ta solution également sur ce site.
@Alle: Fleischwurcht hat seit er sein Ampera besitzt die größten Schwierigkeiten mit dem Voltec-Ladekabel nachts zu laden. Er hat seine Lösung
hier auf dem französischen Forum amperiste.fr gepostet.
Unabhängig von seinem Ladeproblem, ist es auch eine Lösung für unterwegs mit 16 A (bzw. 15 A) zu laden.
Verfasst: 21. Aug 2012 06:56
von fleischwurcht
Ich probiere es wieder auf Deutsch.
Ich lade meinen Ampera in genau 3h45min (ich habe keine Antwort für die 80%). Der Lader kann auf 10, 12 und 16A in der Fabrik geregelt werden (dass kann man dann nicht mehr ändern).
Er kostet 995 USD und zum bestellen kann man ein mail zu "
Information@clippercreek.net" schicken. Ich diskutierte mit Herr Will Barrett, ein sehr angenehmer und "helpful" Techniker.
Tschüss.
Re: Clippercreek-Ladegerät 16 A
Verfasst: 21. Aug 2012 21:14
von Kratus
Toll: mit Herto sind nun drei Elsässer hier im Forum aktiv!
Fleischwurcht, es freut mich dass Du dein Ladegerät-Problem endlich gelöst hast.
Verfasst: 22. Aug 2012 19:16
von vaja
Super fleischdings, je me renseigne en us. Je te remercie. Valentijn
Verfasst: 9. Sep 2012 13:52
von max64ch
Hallo und danke fleischwurcht.
Ich war auch an der Suche eines Charges für daheim.
Habe dann beiClippercreek angeklopft und Herr Willa Barrett hat sich der Sache angenommen.
Er ist superfreundlich und kompetent. Ich konnte ihm alle Fragen stellen die ich wollte. Hat immer bestens geantwortet.
Ich werde nun ein LCS 20 bestellen (795 U$D9 plus den Versand.
Ich hoffe alles klappt bestens. Bis jetzt ist diese Firma nur empfehlenswert.
Gruss aus der CH.
Verfasst: 9. Sep 2012 19:59
von fleischwurcht
Hallo max64ch,
Ich bin froh das Du auch dein Glück gefunden hast bei ClipperCreek...Ich bin sehr zu Frieden mit meinem tragbaren "charger"...Du hast eine andere Lösung bestellt und ich hoffe das die auch so gut ist wie der ECS-20.
Tschüss.
